Csm Davis
- 382
- 83
- Hattiesburg, Mississippi
I have seen this several times and have wanted to post it but have forgotten to do it, check the Axle flange bolts before you leave base. I have seen a lot of them loose and leaking but the most recent one caught me by surprise it is twenty five miles to the base and I was moving trucks to be cut up and I saw a leak but just made sure they were all at least snug, I have found many just loose and leaking but this was a lot closer to being bad than I knew. Truck ran so I drive it from my staging area to my lot AD when I got out oil was everywhere and All of the bolts had backed out half way or more! I know it is a lot of bolts but I would recommend anyone that is driving or towing a five ton to check these bolts and mark them to give you a quick check later.
