VA350
- 0
- 0
- Fredericksburg, VA
I have a MEP-002a that I am having troubles with. When I first got it I went through and replaced all filters and cleaned the fuel system prior to starting, everything looked good. When I went to start it everything was working properly, starter was turning over fine. It cranked over and almost started then the starter stopped cranking. At this point the fuel pumps worked and pre-heat worked but the starter wouldn't crank. Now I am not getting power to anything. So far I have replaced the relay, starter switch, and starter. Just swapped them from a MEP that is working. Any suggestions what else to look at?
