kennys@wi.rr.com
- 23
- 38
- Waukesha, WI
When I picked up the M923 from Sparta a few weeks ago I knew the driver's side door window was cracked. I was sad to find that some one had broke the passanger side after the auction. I looked closer and found the problem. The doors are not lined up correctly. It seems there is more room to the front than to the rear of the door. that causes the windows to hit against the new hard top. So upon further review Toddm discovered that the original door hinges were bent. Not an oops bend but more of a deliberate bend. That helped pull the door out so it would line up with the side of the cab, but not to the front. My question is where do I look more closely? Could the new hard top be installed incorrectly or could the cab be tweaked? It appears to be a new cab as well. I picked up a new door and window assembly for it, it was cheaper than buying just the window. So I even tried to swap out the hinges that came with the door. Any thoughts would be appreciated. I am even debating taking the hinges in to be press bent about 1/16 to 1/8th of an inch. That's about all the room I need to make everything line up better.
