Can you use old rancid diesel fuel?
Mark3395
Geneseo Illinois
I've drained the nasty smelly fuel from a few deuces and have several hundred gallons.
My thought is to poison the biologicals and filter and/or centrifuge it, add some conditioner, thin it with some good fuel, and run it.
Anybody done that? What do you think?
Mark
2,464
Mark
Filter the water and "floaties" out of it and burn it!
You'll probably have a little more pep if you DO mix in some good fuel but don't waste a drop just cause it's old and smelly.:D
dmetalmiki
2,028
London England
WOW! 1000s of gallons of "GO" juice....where did you ever get that from? its GOOD to go if there's no water in it....lucky chap! and just think...diluted with 1000 ltrs of old filtered aqtf you have POWER smooth running and no expense for miles and miles and miles and.....
eagle4g63
34
North/west Indiana
What do I think?!?!
Send it to me and I will thoroughly test every drop of it for you in my deuce.........I will then gladly give you a report on whether it worked or not. :D:D
doghead
4 Star General /Moderator
1,179
You were also told to capitalize(as our rules require).
