Disclaimer: These are my opinions and I am not a licensed electrician. Please proceed at your own risk.
Want 2nd opinion here. If I wanted to run a SX460 voltage regulator on an MEP-003A I think I could set the jumper on the SX460 to 120V and connect it to 3 and 6 from the gen head. From the pic, it looks like 3 and 6 always see 120V.
The SX460 wiring would be:
1 and 2 jumped or used for voltage adjust potentiometer/rheostat (R1 on gen panel).
4-3 jumped for 120V operation.
7 on the VR to 3 on the gen head
8 on the VR to 6 on the gen head
F1 to the gen head field
F2 to the gen head field
Frequency selection to 60, of course.
Does this all look correct?
VR instruction sheet:
http://www.cumminsgeneratortechnologies.com/www/en/common/pdfs/avr/TD_SX460.GB_04.05_05_GB.pdf
Terminal 6 on the VR is generally not used.
The SX460 has:
Voltage adjust. It adjusts the voltage. A pot/rheostat on terms 1-2 can be used as a fine voltage adjustment.
Stability adjust. I think this controls how fast it corrects. You don't want it constantly correcting but you do want it correcting for load changes.
Low Freq setting. It will cut power if the frequency drops below a set level. This helps protect loads that are frequency sensitive.
The SX460 has:
