Whats the cost on one of these?
We have three models of trailers and they are as follows:
MORV ORIGINAL - Ready to Serve
$2995 Economy; Frame/Tub Made Overseas, Assembled in the USA.
$3995 Elite; 100% Sourced, Made & Assembled in the USA
Standard Features:
Complete trailer ready for the road and ready for you to enlist its' services.
1) All metal is powder coated for a long lasting, worry-free ownership experience.
2) Premium LED lighting. All lights are rubber mounted and fully recessed. All wiring is hidden with sealed connections and a molded rubber 4 pin connector.
3) Stainless steel hardware is utilized throughout the trailer.
4) Exclusive patent pending tailgate design. Features a smooth exterior similar to a truck and slam shut, one-handed close operation.
5) Exclusive hidden tie-down system fabricated under the tub rail and under the tongue offering utility while keeping the trailer's clean lines.
6) 2" receiver tongue allows multiple coupler choices such as 2" ball, pintle/lunnete & articulating silent coupler.
7) Lightweight design, weighing just 775 pounds, it welcomes all tow vehicles.
29" Yokohama Geolander A/T tires.
MORV UTILITY - Ready to Work
$3995 Economy; Frame/Tub Made Overseas, Assembled in the USA.
$4995 Elite; 100% Sourced, Made & Assembled in the USA
Standard Features:
Includes everything that is standard on the MORV Original model with the following select upgrades that turns it into a lean, mean, utility machine!
1) Custom made tonneau cover w/ exclusive quick release system. Remove and reinstall in under 30 seconds!
2) Exclusive, patent pending trailer rack system. It's unique mounting allows the use of a rooftop tent without the cost, inconvenience, or weight of a hard lid.
3) Custom made truck quality bed mat.
4) Hitch mounted recovery hook so you can rescue your buddies without unhooking the trailer.
5) 31" General Grabber A/T tires.
MORV EXPLORE - Ready to Navigate
$6995 Economy; Frame/Tub Made Overseas, Assembled in the USA.
$7995 Elite; 100% Sourced, Made & Assembled in the USA
Standard Features:
Includes everything that is standard on the MORV Utility model with the following select upgrades that will have your wife asking you why your sleeping in your trailer in the driveway!
1) Soft tonneau cover is replaced with an exclusive, patent pending, locking aluminum lid. The ultimate in trick functionality.
2) Taller patent pending trailer rack system. The same unique mounting system gives you uninhibited use of the top of the lid for additional storage.
3) Roof top tent.
4) Hitch mounted trailer stabilizer to allow use of the tent when your tow vehicle is unhooked.
5) Max Coupler articulating coupler.
6) 33" BF Goodrich KM2 M/T tires.
-Josh
*Admins, if this type of posting is not ok, just contact me. Thanks*
