- 10,350
- 75
- 48
- Meadows of Dan, Virginia
Yes, you'll find this explained a few times in the old threads.When bypassing the FDC, you pretty much just hook the line from the final fuel filter directly to the hydraulic head inlet, correct? (and then plug up the holes left in the FDC).
I ask because the hose in my deuce is not long enough.
Also, remember to turn down the fuel when doing so, or you'll have some very high EGTs and boost pressures (also explained in the old threads).
The IP without the FDC is an early model and not a rebuilt one.
