Jimma
- 3
- 38
- Hartwell, GA
Post some pictures. Sounds like a cool idea.
You could always fabricate something up for it to be permanently mounted in the map/glove box. Then you wouldn't need a separate battery. A little more work on the front end but better for the long haul.I went ahead and mounted the radio to the inside of the glove box of my M38a1, ran the antenna cable through the factory hole in the back bottom part of the box, and drilled a hole in the very front bottom corner of the box for the mic cord to come out. I stuck the magnetic antenna to the top of the gas can and ran the cable down behind the rear seat, around the wheel well, behind the fuel tank filler and around the side of the kick panel into the glove box. That will do until I can agquire the correct box.
This is in my M35A3. I hung 4 of them from roof bracket and I mounted 2 subs in the bed. I also mount 2 PA's on the front and 2 PA's on the bed rails. You can check out my build thread (link in signature) for more info.That looks good! I don't think I really want a permanent mount though - I just did it that way until I can get the right ammo can to mount the setup in. Where have you go your stereo speakers mounted?
That will be a future mod for my M38a1 - I will have to order a 24-12v converter, as there are no electronics stores around here (2 Radio Shacks I went in didn't have them). I considered running just the cb off of 1 battery, but I don't feel lucky - I'd end up killing it! When I do the converter thing, I am going to run a wire to a small fuse block so that I can power more than one thing like an aux port for phone charging + a radio and cb.Why not power the radio off of a 24 to 12 power converter rather than batteries if you are going to use it in a vehicle?
