Need Help Changing Starter Switch
748
Woodstock, GA
I was going to put a keyed switch in mine but couldn't determine where the four wires would need to connect on the keyed switch. Any help identifying these four wire would be appreciated.
KsM715
142
St George Ks
Get a multimeter with a continuity tester. Take the switch and turn the key to the position where it would normally be turning the starter. Find the 2 wires/terminals that have continuity when the key is turned but no continuity when the key is released. Hook those terminals the 2 wires that go to the stock push button
