DXTAC
- 1
- 0
- Plainfield, Illinois
I did the weather strip on my 1009 for the tailgate window and both doors, and the only problem I have had is that
one of the plastic pieces on the door panel that the weather strip clamps onto cracked and now I don't know if I should
use epoxy, gorilla glue or similar to try to hold it together??? I may just put it together and use a small amount of PL Adhesive between the weather strip and panel and hope for the best. Just be careful, the door panels are a little brittle after 25 years! I got everything from JC Whitney and everything fit like a glove!
Oh, BTW I did not use the special tool to remove the C clip for the handle either, I simply used something like a hooked dental pick to grab the top of the clip and pulled gently. You do not need a tool to reinstall it.
