Braunchitis
- 0
- 0
- Cape Girardeau, MO
Hey all,
I've got a CUCV that's leaking quite a bit (not gushing, but not real slow either) of coolant near the water pump. It leaks whether the truck is running or not, but it leaks a lot more when it's warm. The weep hole (I assume that's the hole on the bottom of the water pump, see pic) is bone dry. It's hard to tell, but I think it's coming from near/behind a bolt that attaches a bracket from the pump to the PS pump (see pic 2). I've tried tightening that nut, but it didn't seem to slow the coolant leak down.
If anyone had any ideas as to how I might be able to fix that, I'd appreciate it!
