firefox
General
- 1,844
- 52
- 48
- Berkeley CA
Does anyone know exactly how the coolant switch works?
Looking for the geek answer.
Bruce
Bruce
It is amazing what one can find when using a search engine.
Bruce, I have not pondered the diagram, but just based on function, my guess is the latter. If it's an actual switch (pressure actuated, likely), then we are using the water as a conductor for a switched circuit, which would be less than wonderfully reliable. Using it simply as the ground path for a sensor circuit would be fine.In particular, is the device an actual switch, or is it just enabling a circuit path to the water and back to the grounded block. Note, the radiator itself is not grounded and there is only one lead to the device.
