bshupe
- 4
- 0
- Mount Vernon, WA
EDIT - Also applies to M1008 unless the rear body mounts dont fit the situation detailed below.
So Im in the midst of trying to install the 1" lift (and new body mounts) on the cab portion of my truck and it would appear that on the 1031 they put the rearward body mounts on the PTO bearing cross member and not the frame or frame perches like on civi or other CUCVs?
If I am reading this right then there will have to be other mods to the body mount to be located in this position.
Does anyone have experience with this? Im stumped on how to access the body mount bolts if they are bolted to the cross member and the cab when there is no (apparent) access to the inside of the cross member to take the bolts loose.
Im sure Im just missing some detail but I thought I would ask here before just jumping in and taking/cutting thins apart.
Thanks!
Thanks!
