panzerwillie
- 123
- 43
- miami florida
Ok so i told my self no more gagets in the M1009, wrong, being kiking around putting electric fan on the cucv and a tack, so finally i did it a few weeks ago, i use the electric fans that come on the red dot A/C kits from the HMMWV from the condenser, all i had to do was trim 1/2 inch from both sides and is a perfect set up on the radiator fits real good , using the upper holes on the rasiator i drill 1/4 inch and bolted to the radiator on top and in the bottom welded 2 flatbar 1 ich wide about 2and a 1/4 with a hole to the bottom off the fan metal shroud and bolted it like the top with bolt and nut very eassy. then with a relay i wire both fans which are 24 volts and using a temp switch wich comes on at 176 degerees and off at 166 degrees to the ground of the relay plus i have a override switch inside, they are mainly off on the HWY and turn on and off in the city, you have to use a external oil cooler which i did about a year ago any ways because of the flush mount of the electric fans. as far as the tach is being cover here before easy mout runs about 2300 rpm at 65MPH with a ligth load on the pedal the converter is a little loose i guess it feels the 60k plus it has may do i 700R4 i got complete with T/C will see here are some pictures...
