700R4 Driveshafts
A quick Q.
Do the CUCV driveshafts work well with the longer 700R4 transmission?
Reason I ask, My "new" transmission was going down the road, then it wasn't. No idea what went out. Ordered a new Mad Dog Level 3 transmission as this has already been a 2 week ordeal.
cliffyp
Brownsville, Texas
I pulled an adapter out of a Blazer with a 700r4/208 from the junkyard. I didn't measure it, but I would say the adapters are roughly the same width. I would think that if the adapter were much thicker, then the output shaft from the 700r4 would need to be longer to cover that distance or it wouldn't seat into the transfer case very far. I think the only variation in my drive line length is the length of the 700r4 case, which is negligible.
Speddmon
Blind squirrel rehabiltator
Cambridge, Ohio
From what I've read, the proper adapter for the NP208 transfer to bolt to the 700r4 is shorter than the one behind the stock TH400. So, with the longer transmission and shorter adapter, you should be just fine. I cannot speak for the NP205 transfer though.
