markehle
- 2
- 8
- Dowling, Michigan
I don't mean to nitpick - did you mean double-spllined?Ouverson will sell one hub and one double flanged axleshaft for a front tandem unlock.
Looks like Ouverson's axles are $225. I don't need bullet proof. Who has OEM double-splined axles, and how much would I expect to pay?
Thanks again.
Putting a single lockout on one of your rear hubs will keep the 2 axles from fighting to go in a straight line. To make a turn without a hub, one of the 4 pairs of duels has to slip.
A single hub in the back has 2 BIG advantages:
1) The original military NDT (we used to call them "tactical") tires are dangerous at best on slick roads, i.e. ice and rain. A lockout on a rear hub will make the whole thing follow in a turn better. The front tires don't have to fight the back ones so much.
2) It will make non-power steering at slow speed a little easier.
I've seen on this website where guys (gals too) will pull a rear axle and replace it with something (maybe a broken axle) to keep the end sealed. That will do the same thing.
If by maximum benefit you mean total disconnects of the steering and front tandem axles, then you only need two locking hubs. One for one side of the front steering axle, and one for one side of the front tandem axle.So if I get this correctly, For the "maximum benefit" for lack of a better term, the correct lock out installation for a 6x6 2.5 is "2" for the front and only "1" on the rear axle. Any side no difference, CORRECT.....?
Yes, for some "modern" part-time 4x4's, where drive flange and wheel hub is one and the same piece. They simply sell better when in the broshure it says "shift-on-the-fly", or "no need to get out -and dirty...", for manual hubs at least............. The automakers, for example, only disconnect one side.
Welcome! Good thought, but it doesn't seem to happen in real life. Millions of vehicles have been built that way over the years, and they do not pull to one side.Hi, my name is Denny and this is my first post. I feel everyone is missing the obvious real reason for having 2 lockouts on the front axle. If you only unlocked one of the axles you would have a pull to the other side. The reason for this pull would br from the drag of the spider gears, diff. lube and any friction of the spinning parts from the axle that is still engaged, especialy in cold weather.
Thanks,
Denny![]()
Perhaps not as much 'fact' than your 'opinion' based on your own anecdotal experiences.Not a thought but a fact. Years ago I had a 1983 chevy blazer with the auto locking hubs and in cold weather the left one would not unlock all the time. As i was leaving work one day I took it out of 4 wheel and unlocked my hubs, well the left one did not fully unlock and I hit a slick spot in the road and ended up making one he11 of an unexpected left turn at 40 mph. The next day as soon as I got to work I threw the truck up on my rack and rebuilt both hubs. never had a problem after that. Also had a buddy with a 78 4x4 ford fullsize that would do the same thing. Not to mention all the other 4x4 vehicles that came in to the dealership with the same problem. Just telling what i have personaly experienced. Also it seemed the taller tire that was on it the harder it pulled.
Thanks for the welcome.
Denny![]()
I'm sure that someone can always conjure up an extreme situation. In your case, you probably should have been in 4WD, plus you were running on a cold soak.To give you another example of the problem, a long time ago, when I first bought a 4WD F250 truck, I took it out to play in some fresh snow. It was very cold, and the snow was about 4 inches of powder. I found the truck had so much traction in 4WD that I decided shift it into 2WD and drive along. I started up a small incline, and heard a "brup" "brup" sound, and then noticed that my rear wheels were powering along past my front wheels as I started into a spin. The "brup" sound was the noise made when my front wheels stopped turning, and started skidding on the snow. The reason they stopped turning is the cold oil in the differential required more torque to turn than the snow could provide, so the wheels skid to a stop.
I am certain that if you only have one lockout hub on your front end, your vehicle will be prone to skidding the locked wheel in slippery conditions.
If you don't believe it, you can prove it for yourself. Jack the front end of your truck up, put the transfer case in 2WD, and lock only one hub, and try turning the two front wheels. You can easily feel the extra drag of the differential in the locked hub.
-Chuck
