YellowHammer
- 0
- 0
- Augusta, GA
I just replaced my direct drive starter for a gear reduction starter as the old was on it's way out. The truck sat for a month before I got around to doing it. After the new starter was in I hook up my batteries and go to start it. The starter fired fine but I think I lost prime in the fuel line. So I stop to go prime the fuel system and all of a sudden the starter begins turning over without the keys in the ignition.
I'm right at the batteries so I quickly disconnect the batteries.(ran about 10 seconds) I figure that the starter relay went bad since that's such a common problem so I replaced it. I go back reconnect the batteries and they spark like there's a dead short somewhere. In the short time I had the terminal on the wire going to the glow plug relay already warmed up a little. I disconnected the glow plug relay and tried reconnecting the terminal again and still had the terminal spark severely.
Any ideas on which way I should go from here?
