- 10,350
- 78
- 48
- Meadows of Dan, Virginia
You probably used a "Megger", pretty expensive piece of equipment for a normal mortal....
And you also don't want to let your coworkers near it when it is signed out - we had a new mechanic in the maintenance shop try to demonstrate his toughness by shocking himself with itHad to get a cert to use that meter . Nick name was biddle /bond meter. A t tool crib had to leave brass tool check with ss# on to make sure it got back to tool crib.
No the 809s have them along with all the 900s, you can use a 900 PCB on a 809 series but you CANNOT use a 809 PCB on a 900Is this box unique to the 8.3 powered 900 series trucks? It seems as if the newer trucks have the more complicated PCB.
