- 3,657
- 27
- 48
- Dallas, Texas
In the 818, I turn the battery switch ON and there is something odd going on. This is the main power switch for the truck I assume.
Normally, when on, the voltmeter should read in the low green, and after starting, the voltmeter should read higer in green, as it is charging.
What I am getting, beside an intermittent switch, which i have to flip back and forth a few times, this s getting worse too.. is that when I turn the power ON, the voltmeter reads in the yellow, and during starting, the truck cranks properly, as fast as usual, and once started, the needle is just into the red on the voltmeter, but I am finding the batteries not being charged properly.
I suspect some kind of open or high resistance connection between the voltmeter, alternator, switch, etc. I understand this switch has several terminals, not "two" like any sane person would have designed, and then used relays.
Has anyone seen this kind of thing? Bad switch?
I will be checking the schematics in the manuals before too long.
Thanks,
Thanks,
