parlusk
- 3
- 18
- southwest virginia
VERY NICE!!!!!!! ![Razz :razz: :razz:](https://www.steelsoldiers.com/images/smilies/icon_razz.gif)
I got a 80 cu inch 12v/110 freezer that will pull 1 amp and 80w. So my batteries should able to support that plus few other goodies. I will be installing 200w from the solar panel. Here are the installation pictures...
I hope this link help: 80 Qt Portable Chest Freezer Refrigerator Compact 12V DC AC Power Cooler | eBayIf that is1 amp at 110V does that not equal almost 10Amps at 12 volts?
Now u tell me....That is an impressive truck. Rather than towing a M105 to protect your batteries you should get yourself a 105mm Howitzer. People will think twice about tailgating you when they are staring down the barrel of an artillery piece.
I know that feeling, all this year we've been un-pluggedNow u tell me....
I am extremely happy with the setup. It is officially unplugged my 240V from the house where it is parking. It is completely on its own/stand alone powered. The only think it need a generator for is AC. I have a 12V heater and loving it.
Wow.. just two (2) 6V? Amazing..... I have 5 full size batteries from Costco (Group 4). I also got a charge controller that is capable of inputting wind mill power too.we are running on 2 6v interstates.
I am soooo glad I ran across this because I'm getting ready to put solar power in my M109RV and this can be rather confusing at times even though I was an electrician for about 6 year...years ago. Do you happen to have any recommendations? I'm wanting to have enough power to run a small home in my M109RV....I guess equivalent to a 5500 watt LP generator.I already have two additional batteries and now adding 3 more. I am running out of space. So made a 12 gauge box with 3 slots dedicated for batteries, one slot for solar charge controller and lowest part for solar dump load. I also got a 10 gallon propane tank sits on top of the whole.
I also have two file type of locks for the battery door and on Master lock for the propane tank. Installation is next.
Seems like a nice project. Some points with the placing of the tank and batteries though.
When I built this system I have consider the heat and propane expansion. The tank is 10 gallon (40 lbs). It is double the size of the standard BBQ tank but it is skinnier. I always tell the gas attendent to fill only 9 gallon so leave some room for heat expansion. However, right now it is winter and not that hot. Even with summer 9 gallon will be fine. Secondly, there is a safety relief valve in even tank. So it the pressure is too high due to heat, it will release itself.1) That high up, doesn't it bring your tank high up exposed to the full power of the sun when not driving? .
I have tested for all leakage but couldnt any. I only turn on the propane when I am stopped and cooking. Otherwise, it will be completely off and the lines will be bleed before driving. Secondly, all lines never enter the living spaces. I dont cook inside the camper. I have good fittings and properly installed and double check everything. Even high pressure propane is only about 20 psi.2) Propane and butane are heavier than air, so escaping gas will go down. Outside is no prob. but what about leakage of your lines into the truck? I would make sure I have some venting holes in the bottom of your living space. .
I am sure LEO and firefighters know what to do with damaged batteries. I have seen battery damage even at regular passenger cars with severe impact. I place the tank high enough perhaps 99.5% of car/truck wont able to reach. Once again, lines are bleed before driving.3) A truck rear-ending a screen full of batteries is also not a nice view. Better put some danger signs on that screen so, in case of accidents or a roll-over, leo's and firefighters know what the liquid is that is escaping from a deformed (batteries damaged and leaking) but still closed screen (nobody sees the batteries) is not drinking water but a liquid hazard to touch that will eat through your gloves and cloths like nothing. .
Thanks and thank you for your comments. I have considered all of your points above before making this.Having said that, very nice. My late brother would have loved it, he always had his living boat (100 years old cargo barge) full of such stuff to make it float-alone and independent.
I debated about this isse in my head for few weeks. Bottom line is warranty. Costco give 100 months warranty on the batteries and great return policy on other items including solar panels. Anything go wrong I know they would back up the exchange or return. 100 months is 8.3 years... I would check batteries every year or so to test the functionality if no up to par I can also take them back to Costco.I am soooo glad I ran across this because I'm getting ready to put solar power in my M109RV and this can be rather confusing at times even though I was an electrician for about 6 year...years ago. Do you happen to have any recommendations? I'm wanting to have enough power to run a small home in my M109RV....I guess equivalent to a 5500 watt LP generator.
I ran everything with 12V or 12V to 110V inverted. I only use generator for AC. I have 12V heater, all LED lights both interior and exterior, TV, Ccomputer, PS3, Ham Radio, electronics charging and so on.
I did not thought you would have done it this thoroughly without considering a lot of options and probable problems. Never hurts to say it and it might trow up some things that other people doing similar things have not thought about. I am also sure that professionals know what to do (or better, what not to do) with batteries etc. It was more like something is leaking and maybe in the hurry a professional or somebody else helping out does not realize soon enough what is happening. It like with so many things, we are not talking about the 99% where we took precautions but about that one freak situation out of the blue.... I am sure LEO and firefighters know what to do with damaged batteries. I have seen battery damage even at regular passenger cars with severe impact. I place the tank high enough perhaps 99.5% of car/truck wont able to reach. Once again, lines are bleed before driving.
Propane has been run inside RV, Campers, trailer houses, etc. for decades. All of my builds have propane run to the inside. If you look around you'll see many trailers, campers and house, that have the tanks sitting on the front tung, often in the sun. Some now have covers (more for looks than to block the heat) and all have "over pressure vents".Seems like a nice project. Some points with the placing of the tank and batteries though.
