- 10,350
- 92
- 48
- Meadows of Dan, Virginia
With power outages popping up so often these days and so much talk about generators, I thought my solution may be of interest.
It is based on the ability of NiCd cells to take on a charge at a high rate, perhaps ten times that what's normal for Lead Acid types.
Going on two years now, my xm757 uses NiCd cells for starting and also has a 60 AH bank of cells to supply a 1KW pure sine wave inverter.
In a power outage emergency, the Nicads will supply power for lights and a TV or Computer for 10 hours or more. Not much perhaps, but the 100 amp 28V generator on the truck recharges the cells in less than an hour at high idle. This cycle can be repeated over and over without harm to the Nicad cells.
That's it in a nutshell, it works great, my only problem is that virtually all new inverters cut off at about 22VDC (to keep from harming lead acid batteries), while I'd like to see a cut-off of about 19 volts, which would be best for the Nicads.
Older non-computerized inverters will do that, so I'm still looking for one those, that would be a better match for my system.
