Inventory List: Pioneer Tool Trailer
NMC_EXP
13
Raton, New Mexico
My Pioneer Tool Trailer was transferred from the feds to a county govt. The county removed the box and used the frame. I bought the box.
There were no tools or genset in the box. It did contain a seven page document titled:
COMPONENT SUB-HAND RECEIPT
TOOL OUTFIT, PIONEER, PORTABLE ELECTRIC TOOLS
This is an inventory list of the small items in the trailer. At some point it got wet and mildewed, but is still fairly legible.
A couple of folks expressed an interest in this. I made a .pdf copy of it (9,000 Kb) and have attached it to this thread. Use it as you see fit.
Regards
Jim
maddawg308
813
Appomattox, VA
For those who can't read some of the .pdf text, due to font or the mildew on a couple of the pages, I've gone through it and pulled the data:
1 Generator Set, 6115-00-017-8237
2 Reel with cable, 13217E0412
1 Chuck, drill, 3460-00-268-9220
1 Chuck, springloaded, 5130-00-699-9868
1 Chuck, wood bit, 5130-00-541-3848
1 Goggles, industrial, 4240-00-052-3776
4 Lamp, incandescent, 6240-00-553-1881
100 Splice, conductor, 5940-00-665-9568
2 Tape, insulation, 5970-00-419-4291
1 Handle, drill, pressure, 5130-00-571-6469
1 Adapter, Socket Wrench, 1/2", 5130-00-516-3220
1 Adapter, socket wrench, 3/4", 5130-00-541-6728
1 Socket, taper shank tool, 3460-00-232-8117
2 Socket, taper shank tool, 3460-00-227-7520
1 Socket, socket wrench, 5130-00-540-0568
1 Socket, socket wrench, 5130-00-540-0570
1 Socket, socket wrench, 5130-00-540-0672
1 Socket, socket wrench, 5130-00-541-5175
1 Socket, socket wrench, 5130-00-540-0571
1 Socket, socket wrench, 5130-00-541-7839
1 Socket, socket wrench, 5130-00-540-0574
1 Socket, socket wrench, 5130-00-540-0567
1 Extinguisher, fire, 4210-00-889-2221
6 Blade, circular saw, 3230-01-122-4991
1 Floodlight, electric, 6230-00-815-5022
1 Cutter, drum deheader, 5110-00-426-9664
2 File, hand, American pattern, 5110-00-250-6512
2 File, hand, parallel rd, 5110-00-782-7491
2 File, hand, parallel, 5110-00-965-0608
2 File, hand, parallel, 5110-00-323-4732
2 Handle, file, wood, 5110-00-595-8325
2 Pliers, slip joint, 5120-00-551-6778
1 Wrench, open end, adjustable, 5120-00-240-5328
1 Extension, socket wrench, 5120-00-449-6656
1 Bit, screwdriver, 5120-00-541-6729
1 Bit, screwdriver, 5130-00-516-3234
1 Bit, screwdriver, 5130-00-529-4944
1 Bit set, center, 5133-00-441-3991
1 Drift, drill, 5120-00-224-8950
1 Drill, masonry, 5130-00-277-2704
1 Drill, masonry, CS sintered, 5130-00-277-2699
1 Drill, masonry, steel, 1/2", 5130-00-277-2698
1 Drill, masonry, steel, 5/8", 5130-00-542-4764
1 Drill, masonry, steel, 3/4", 5130-00-277-2702
1 Drill, masonry, 1.0", 5130-00-277-2705
1 Drill, twist, morse taper, 5133-00-189-9318
1 Drill, twist, morse taper, 5133-00-189-9326
1 Drill, twist, morse taper, 5133-00-189-1331
1 Drill, twist, morse taper, 5133-00-189-1339
1 Drill, twist, morse taper, 5133-00-189-1345
1 Drill, twist, morse taper, 5133-00-189-1349
1 Reamer, machine, 3455-00-245-4042
1 Reamer, machine, 3455-00-245-4044
1 Reamer, machine, 3455-00-837-9543
1 Reamer, machine, 3455-00-541-3096
1 Saw, circular, electric, 5130-00-889-8991 (Milwaukee 6460 10.5")
1 Wrench, impact, electrical, 5130-01-087-6841 (Sioux 330)
1 Hammer, electric, 5130-00-112-5334 (Black & Decker 5025)
1 Saw, reciprocating, electric, 5130-00-720-0654 (Black & Decker)
2 can, utility, gasoline, 7240-00-878-7217
1 First aid kit, 6505-00-902-1200
1 Spout, cap, flexible, 7240-00-177-6154
1 Funnel, 7240-00-559-7364
1 Drill Set, twist, 29 pieces, 5133-00-293-0983
1 Oiler, hand, 4930-00-554-6778
1 Drill, electric, 3/4", 5130-00-177-7002 (Black & Decker 1405)
1 Drill, electric, 3/8", 5130-01-554-6778
1 Handle, drill, 5130-00-571-6469
1 Can, utility, 7240-00-222-3088
1 Drill, electric, 3/8", 5130-00-293-3456 (Sioux 8040)
1 Saw, cutting, rescue, 4210-00-134-8954 (Partner K1200) or (Homelite XL-98A)
1 Tool roll, 5140-00-315-2781
incl: Bit, auger, 7/16"-12", 5133-00-360-2730
Bit, auger, 3/4"-12", 5133-00-260-2732
Bit, auger, 3/4"-30", 5133-00-360-2733
Bit, auger, 1"-12", 5133-00-360-2734
Bit, auger, 1"-30", 5133-00-541-3751
Screw, point, 12"-2", 5133-00-529-5720
Screw, point, 2"-30", 5133-00-360-2737
maddawg308
813
Appomattox, VA
I did not see a tool trailer manual in the SS reference section.
Looks like I wasted my time and a thread.
No you didn't waste time, perhaps there are a few things in your scan that my list doesn't cover - I got mine from the last version of the pioneer tool kit manual, I think your list is from an earlier loadout.
Also, the tool kit trailer manual is NOT in the SS reference section.
M813rc
3,806
Near Austin, Texas
No Jim, not wasted, at least for me.
I think lots of folks in the future will find both yours and Maddawg's info long before they might find a manual. And I personally like to see the original documents.
You both have my thanks.
Cheers
chris kappes
Pisgah, IA
If anyone is looking for a manual, I have a copy of the 1977 version for the larger, second version of the tool trailer.
Mine came with the 1960 early tool trailer I just picked up. If anyone wants info from the manual, let me know.
Also, if anyone ever found the early version manual, I could use some info from it.
