Mraps on the front
bones1
Southern Maryland
Well It's tough by yourself, these are right stout(I did get the neighbor lady to help) but the fronts are on and man what a difference it makes. Makes the stock Deuce tires look silly. Now to flip 4 rear hubs and continue. I used 6 adapters from Peashooter and the machining and fit were absolutely perfect. I would highly recommend these adapters. Now for three lockout hubs.
bikeman
501
Ft. Bragg, NC
That does look sexy.
Do you loose any abilities in turning radius or anything? (have you had a chance to find out yet?)
bones1
Southern Maryland
Never thought of a Deuce looking sexy but if you say so. Thanks . I still have to flip the hubs on the rear so it might be a day or two before I drive it.Still have to change all the gear oil as well.
bigbird1
Northwest, Indiana
i just put on a set as well, (20 bolt rims) they seem to turn better than the stock NDT's They look great , get the others put on you'll love it . the back hubs took about a hour a hub if you get with it , clean them up and repack .
