ODdave
- 41
- 0
- lansing michigan
Your 208 fronts will work. Different seal if I remember correctly.
I Belive you will have to change the seal but the flange will fit
what did you use to resize the bearing yourself. I am looking at taking it to a machine shop for this because I don't want to screw it up. I have been busy with other smaller items because I am still waiting on my trans controler from TCI.
I am very unhappy with TCI. I sent the unit to them on the 10th. they received it tested it and told me there was nothing wrong with it on the 17th. They were going to replace the hand held unit due to the blemish in the screen and after I paid them for the return shipping (yes, you have to pay for their mistakes) they were supposed to have it in the mail to me on the 18th. I called them on the 26th to learn that they procesed everything except putting it in the mail. On the 26th it was still at their factory and since the factory was closed unitl Jan. 3rd it would not leave unitl then. I now know TCI stand for Total and Complete Incompitance. I think they were lying about the controler being good also. If the controler was good then the wiring harness they sent is bad. At this time it is going to be second week of jan. before I know. I did put a unique mark on the controler before sending it to them so if they do not send me the same one back, I will know.
I plan to start the 205 tcase breakdown in the next couple of days, I need to send the rails to ORD. I also need to resize the input bearing. I currently have my steering column apart waiting on a new wiper switch. It is special order at Oriely's, LMC has one but they are the same price so I am getting the Oriely's so so I do not have to pay for shipping. I have taken a closer look at it and I understand why the seal has to change, the seal actually rides on the yoke flange and not on the ouput shaft. This is not a problem since I am doing a complete rebuild on the 205 and it will have all new seals.
