- 2,035
- 221
- 63
- North West Arkansas
Arrived at the forestry compound late as usual, hooked up the towbar and light set, caged(?) the rear axle brakes couldn't on the middle axle, looks like commercial air cylinders there, made sure everything is in neutral, then gave it a tug, both axles are locked, all eight tires are dragging. Six forestry mechanics are standing around and the best they could do was hook up the air lines wrong. Got to be closing time so I dragged the truck about 100 yards in grass and gravel and the wheels on the passenger side on both axles turned, rocking back and forth did nothing to loosen the wheels on the drivers side. When I hooked up air to the 932 I could hear the tank fill with air and the gauge would show about 45lbs of pressure along with a significant leak on the rear most brake cylinder on the drivers side rear axle(Gaged One). Have a look at the pics., I am heading back down there Saturday moring!
