hokie8358
- 0
- 6
- backwoods ,virginia
NEED MAJOR HELP ON THIS ONE SINCE ITS WINTER TIME!! JUST SWAPPED IN A BUILT CHEVY 502CID MOTOR FOR THE TIRED WEAK
6.2 DIESEL! I JUST PUT IN A BRAND NEW 180 THERMASTAT IN WATER NECK AND TOPPED RADIATOR OFF WITH 50/50 ANTIFREEZE.
THIS MOTOR DOES NOT OVERHEAT AND WITH THE FAN ON HI,I CAN NOT GET ANY HEAT TO BLOW OUT FOR NEARLY 20 TO 30 MINS!
THEN AT BEST ITS LUKE WARM.BEFORE WITH DIESEL,I WAS SWEATING WITHIN 5 MINS AND CUTTING HEAT OFF! I CAN ALSO AFTER 10 MILES HARD DRIVING,STOP THE TRUCK AND POP THE RADIATOR CAP AND ONLY WARM VAPORS POUR OUT!! NO PRESSURE AT ALL! ITS ALMOST AS IF THE COOLANT SYSTEM IS NOT CIRCULATING THE WATER! I VE NEVER SEEN THIS BEFORE IN ALL MY ENGINE SWAPS!!I AM LOST, PLEASE GIVE ME SOME INFO ON THIS ONE!!!
