hokie8358
- 0
- 6
- backwoods ,virginia
Just had gen.2 light come on, so i isolated the gen. And checked with volt meter. Was reading 25.9 on it and 30.7 on driver side! So i had a spare and put it on the pass. Side and rechecked it. Now dash gen. Light is off and checked with volt meter and its pulling 30.9 ! So i pulled my headlights since i just installed new ones and they worked fine. Now my front side markers are not burning as well as my park/signal lights in the front!!! So i took the bulbs out and hit them with the volt meter and touched bout the prongs in the sockets. One side is showing 10.6 volts and the other showing 6 to 7.1 volts. So i checked all 4 of them in the front and its around the same. When i went to put the side marker light in i noticed it was barely burning on the filament! You can hardly see it in the day time! So i am seriously lost on this one!!!
Need a starting point to look at for the under voltage i am assuming!! This is a new one on me!!! As for rear lights there burning great just like headlights!!
