archer67
- 0
- 0
- lebanon , CT
my turn signals stop working today after a short drive. I am working on getting my duece an the road. When i got the truck it did not have a flasher or a turn signal switch so i put a used switch and a new flasher on everything worked but one light, changed the bulb everything worked great. I took the truck for a ride through some corn fields and hay lots when i got home no turn signals. i let it sit for a few hours tried it again each light lit even the on on the switch but no blinking. Thats when i heard some sizzling ans saw smoke coming from the flasher. after a quick check all the wires around the flasher and switch looked good, almost new no cracks or bare spots.
I plan on checking the TMs and trouble shooting tonight does anyone know which ones? also anything obvious i am over looking? I did notice that the ground to the flasher was a little loose. Should I use a different bolt other than one of the ones that hold the flasher to the firewall for the ground?
