Vhyle
- 1
- 0
- Clarksville, TN
So I don't hijack the other "Electrical" thread...
I cleaned all the bulb sockets and contacts on the instrument panel today. After reassembly, here's what I have that works:
Wait to start/water in fuel (same as before)
Gauge illumination
GEN2
Blinker indicators
I'm missing the sockets for the hi beam indicator, and the center illumination. Seatbelt indicator is missing a bulb. All other bulbs are good.
Nothing else works.
Now, when on KOEO, ALL of the indicators should be lit, correct? Oil/coolant/seatbelt/GEN1 and GEN2, etc. Everything?
With the test light, I checked each contact on the instrument panel harness, and most of it is getting power. Both GENs (one is brighter than the other, so I'm assuming one is getting 24v and the other 12v). Hi-beam indicator is also getting power, although I'm missing the bulb socket for it.
The voltmeter wasn't working before, but I found that the 10a fuse for it was blown. One of the terminals on the gauge was loose, which is probably what caused the fuse to blow. I replaced it and tightened the terminal. I haven't driven it yet so I don't know if it works for sure yet.
I know both GEN lights are supposed to illuminate on KOEO. Is everything else supposed to as well?
Another thing to note is that I rebuilt the driver side alternator, and its output is great. The pass side alternator still needs to be rebuilt, since it's not doing so well. This is still main priority. I'm mostly asking about the lights right now.
Gauge illumination
GEN2
Blinker indicators
Nothing else works.
