deathrowdave
- 85
- 28
- falmouth, ky
I agree just rebuilt a Dodge with a Dana Axle new pins and bushings / or ball joints will more than likely repair the problem . Mine were shot hard to determine until removed for repairs.
Just so you know, king pins and ball joints are different setups.I agree just rebuilt a Dodge with a Dana Axle new pins and bushings / or ball joints will more than likely repair the problem . Mine were shot hard to determine until removed for repairs.
I was talking about set in the spring over time. What I have seen from worn bushing-springs is set on the springs. Wear will also decrease the spring force. Of course damage to the bushing will also decrease the load plus induce play.Engineers! How do you figure when the spring compresses it decreases force on the bushing? It is bearing directly on the bushing. The upper king pin is slightly tapered towards the top and the only force on that joint is lateral so as it gets lateral force the bushing will try to ride up the pin, it is prevented from doing this by the preloaded spring. Any movement up will only increase the force down exerted by the spring. Now, if the bushing is cracked or worn or the spring has lost tension then you have the death wobble situation. Once that oscillation starts it will do a lot of damage to the bushings in short order. You also have to figure in the roller bearing on the bottom of the joint, I have seen these rust solid from lack of grease. There are also preload shims on the lower that need to be set.
Rick
I said with new / tight ball joints.All of the same things pertain except it is much easier to detect worn ball joints. Jack under the axle and put a pry bar under the tire and pry up and down, if there is play the lower ball joint is bad. Grab the top of the tire and push in and out, if you have play the upper is bad. Ball joints got a bad rep for a long while but they have gotten them sorted out and they are every bit as strong as the king pins now. Changing them is a different story!
That is fine as long as the bearing on the bottom is not bad or if either pin is not scored and worn. I have had to replace the upper king pin on several customers trucks.Ok, it appears that my recent “expert” post was deleted - see what happens when some of you start swearing at me, let's keep it to the learning - regardless of how much you want to swear.
Key lessons learned on CUCV mid 80's with Dana 60 front end death wobble:
Death wobble is a very specific and violent front end shaking at 20-30mph on bumpy roads with an otherwise perfectly driving truck. This is a very specific and identifiable issue - this is not a mild shimmy or an irritation - this shacking is so violent that is requires bringing the truck to a complete stop prior to continuing.
1. New king pin springs is key, even good looking spring may be dysfunctionalView attachment 414448View attachment 414449 - see photos - this is a 30 minute job and the kit I bought was $28. Attached are photos of the "good" springs I apparently had - see the difference yourself.
2. Steering dampener - change that - this is a $40 -$60 part and 10 minutes to change
3. Front wheels balanced well - some have gone as far as beeds inside the wheel to get dynamic balancing.
That's it - it fixes the problem and makes the truck wonderful to drive again.
Most shops no longer have the skills for these front ends and they will cost you money - If you have money then take it to the shop. Otherwise follow above.
please tell me how u replaced the sway bar bushings....as im having a really tough time pressing them in......thanks mario
