epitts
- -1
- 18
- Terre Haute, Indiana
If you don't mind me asking, what type and model is the pump?
The lever is all the way back toward the bell housing as was mentioned above which would be CCW.On the oil light, I think this is normal for the non-running situation. The low oil pressure light will come on when the start-run-stop switch is in the run position, and the engine is not running: the oil pressure sensor is energized, but there is no oil pressure because the engine isn't running. If the light stays on once the engine is running, and the oil pressure gauge shows no pressure, then you have a problem.
On the pump lever, it is either all the way clockwise, or all the way CCW. see leedawg's posts #31 and 32 on page 4 of this thread. I think he is saying all the way CW.
It does not hook onto anything it just pushes that shut off lever into the position you found it when you opened the pump up by a spring loaded device in the solenoid. WHen the solenoid activate it moves that lever thing forward and if the fuel shut off lever is free i follows moving away from the radiator toward the bell housing of the motor.OK, thank you.
I had the cover off last night, and the hook didn't seem to be hooked into anything. The strong side of the hook just seemed to be lightly pressed against the radiator side of the shut-off lever arm, with the hook side even closer to the radiator and connected to nothing. I'll look again tonight, but did I miss an obvious connection in there?
The cutoff lever was sticky, but I got it freed up, so it moves when the outside lever is moved now.
I tested the solenoid by connecting it directly to the batteries, and it worked, but I didn't hear it click after it was reinstalled. Maybe the leads are backwards?
I checked for and did not find any debris in the pump or check valve when I had the cover off.
Most likely your shut off valve is also siezed up from sitting for to long with old fuel in it in the off position. No fuel out of the injector lines means the motor wont run..Thanks guys for the help!!! I went to open up the IP and I do not have the right size Trox Tamperpoof driver to remove it.
Off to town on Monday I guess...
I did a little more testing and I have fuel coming out of the return, but none coming out of the lines to the injectors. I put power to the pump and I can hear it click. Will take it apart when I get the trox driver.
Yup that is what I did. However when I got the pump back after it had been rebuilt I was unable to get it in time properly with where the shaft was set in the timing gear hopefully you do not run into this problem otherwise you will have to take the shaft out of the timing gear to set it to the proper spot so the pump is timed right to the flywheel marks.I got the Pump pulled, but I could not figure how to get the pump shaft off of the timing/drive pulley.
FYI, I took the pump in and the shop does not need the shaft to rebuild it. They have shafts to use for testing.
LOL Yeah I was told the exact same thing. Um so quick question were they lined up when you pulled the pump off? If so Id say you should probably line them up again. I personally dont see why it makes any difference what so ever I mean its just turning the pump. The only thing I can think of is perhaps you could be 180 degrees out of time if the dots are not lined up. Are you sure you are on the compression stroke on Cyl #1? I pulled my valve covers and verified this and then set the shaft into the timing gear so my dots lined up and the lines lined up. However if your stuff is lining up as is id say you should be good to go. Crank her over and fire it up. Its either going to run or its going to run like crap and be very hard to start with fuel pumping up to the injectors. If that is the case you are probably 180 degrees out of time and need to spin the crank around again till the shaft lines up with the dots on the pump. The other thing you could do is just put a really big flat head screw driver in there and spin the pump 180 degrees and the dots should line up but your timing line may not line up then..Lee, I got my pump back from repair and it lined OK with the shaft like I left it.
Twenty degrees on the motor and the two lines on the pump all line up.
But the guy at the pump shop said to make sure the two dots, one on the shaft end and one inside the
pump line up. I looked and my dots are 180 degrees out. But if the shaft is not keyed it should not make any
deference, Right???
Thanks!!
