should I remove/bypass the GP resistor with Wellman 070s?
doghead
4 Star General /Moderator
1,193
Reading comprehension and writing skills are a must when using written language to communicate.
Perhaps the OP should have just read all the other well written threads covering this in great detail (and that have been moderated well enough to ensure they are correct and useful).
Skinny
501
Portsmouth, NH
It has been stated, that is not exactly how it works. In 24v configuration, the resistor draws extra amperage in order to drop the system voltage which is pulled from both batteries. In 12v configuration, only the GP's draw amperage from the first battery. The draw on the first battery is probably very close in both 12v and 24v configurations, it is the second battery that is no longer do anything after the bypass mod.
The numbers are probably not exact but pretty close. According to Ohm's Law, the resistor bank would have to draw as much current as the entire GP system in order to drop the 24 volts in half to 12 volts.
If you understand this or not, it really makes no difference. You should be retaining the 24v resistor system if you plan on being jumped by a NATO cable sometime in the near future or bypassing the resistor in 12v configuration if you want to eliminate any GP circuit potential issues. The rest is just boring details...
Vhyle
Clarksville, TN
May I suggest that you check the voltage potential between that diamond shaped connector and ground to validate that there is a 12 volt potential?
If we are talking about the same connector, it is supposed to feed 12 volts to a considerable number of items. Check the image in this post: http://www.steelsoldiers.com/showth...g-By-Pass-Help&p=948468&viewfull=1#post948468
The connector I believe you are referring to is labeled "12V bus".
I would be a tad concerned if you were seeing 24 volts off of that connector.
Please report back what you find.
That's the one, the 12v bus. I measured it - between that connector and engine ground, I'm getting 12.5v.
Ferroequinologist
Resident railroad expert
4,813
750
Liberty Hill, SC
I did the mod, mostly because one of the gp was busted off in the head when I got the truck. So I was always with 7 max GPs. I figured they would start burning out, so I bypassed the 24v part of the GP circuit to make them run on 12v.
One day I'll need to get that thing out somehow.
Vhyle
Clarksville, TN
I know I have at least one bad GP on the passenger side. Every morning it blows smoke out that side on a cold start, and it skips a bit for a few seconds. So I need to do this bypass like yesterday. Tomorrow I'm doing it, among other things.
