Fellow SS'ers ![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
I am in the process of looking for a way to "lock down" the master switch. Lock down in such a way that no matter if you switch it on or off nothing electrical gets powered on, until the keyswitch I am going to install is turned to the right position.
ie like this
Master Switch on, Key off - No power
Master Switch on, Key On - Power
Master Switch Off, Key On- No Power
Simply wiring a keyswitch before the master switch is the solution I have come up with so far. My problem however consists of making sure I actually get a keyswitch that can sustain the voltage/amperage that normally goes through the master switch. As far as I understand, the M35 etc can't start without the master switch on, which at least to my conclusion means that the cranking current actually passes through the master switch. And so far I haven't been able to find a key-switch that can withstand that kind of amperage.
Unless all the master switch does, is to effectively trip a relay that then handles the voltage/amperage that goes through the truck and thus doesn't pass the load through the switch?.
But I apologise in advance if the TM actually mentions this and provides charts that detail it. But I figured those parts were only covered by a wiring diagram, which I would have to admit I am not an expert at reading at all.
But thanks in advance for any help or direction I can get in regards to this.
ie like this
