Steering Stabilizer
Barneyszoo
12
Riverside, CA>
Has anyone put a steering stad. on a m35. did some off roading and the steering wheel jerked and I almost broke my elbow on the door handle. Ouch!
ivbeenrokd
knoxville, tn.
I was thinking the same thing the other day. I noticed with the larger tires a dip in the road pulled the wheel a little more than I'm use to. Not too bad, but enough that the though crossed my mind.
steelandcanvas
87
Southwestern Idaho
Just a cautionary note for Folks that haven't driven the Deuce off-road very much. NEVER wrap your thumbs around the steering wheel! Grip the wheel with four fingers and keep your thumbs up touching the front side of the wheel. You will eliminate the possibility of broken thumbs this way. Don't laugh, I have actually seen Soldiers with broken thumbs because they held the wheel incorrectly while driving off-road.
rattlecan6104
Oak Harbor, WA
It looks like I have come up with a potential solution, I just need to track down a pair of steering stabilizers with at least 9 inches of travel before I continue further, but from my half way mock up, it is doable.
o1951
155
Bergen County, NJ
I suspect a gas shock for rear of a car would do it - long travel, double acting so should only need one. If they are gas charged, I believe they work in any position.
tourus
madison me.
while working in a school bus shop a few years ago we put steering stab. on all of the buses. we got the kits right from a GM dealer like 40.00 dallors for kit and 40.00 for the shock. I still have the paper work because I have used the kit and shock on my pickup works great and cheaper the than any I could buy at napa. just go ask a dealer for the kit for a class 8 truck. the one I dealt with had one in stock all bolt in took about 1 hour to do.
271
10
SW Ohio
This thread got the gears turning for me. After some violent steering feedback in the mud ruts at Haspin, I thought it worth a try.
The truck has 900x20 NDCC tires all around.
The damper is a Monroe 555949 Gas Magnum RV steering damper. Plenty of stroke at 12.25 inches. Rockauto - $29
Brackets were made from available scrap.
I haven't tried it off road yet. On road it dampens oscillations induced by pot holes and such. I don't notice damper drag when turning but return to center is slightly slower.
We'll see how it works in the long run. The yellow has to go and I'm sure it will work better in green.P1150005.jpgP1150006.jpgP1150008.jpgP1150009.jpg
welldigger
Benton LA
Its funny this thread popped back up. There's another thread just lime this being discussed in the hotrod forum. I'm definitely interested. We aren't famous for good roads here in LA.
