Rebar
- 0
- 6
- St. Louis/Missouri
The winch cable was pulled out of the chain connector lock nut on GL acquired M817. Finally got the locknut loose. What are the secrets to getting a secure connection? Do I pass the lock nut up on the cable end, ![image.jpg image.jpg](https://www.steelsoldiers.com/data/attachments/279/279405-8c5d745a6acd5dc367d94dd5ebd94415.jpg)
put the anvil in the base and then just tighten it down? How far do you push the cable through to get it locked by the anvil and nut assembly? I have never done this before and cannot find a page describing procedure in TM. Obviously this is critical step if I ever want to have a functioning winch on M817. Any tips would be appreciated.
Rebar
![image.jpg image.jpg](https://www.steelsoldiers.com/data/attachments/279/279404-c921477b3a9c1236b01762185e74d4b0.jpg)
Rebar
