Info Sep 2005M35A2 w/o Winch
Serial Number: 052515917 (Frame Number)
Registration Number: 04L55470 (Identification Number on Data Plate)
NSN: 2320000771616
There's no visible numbers on the bumper, but the hood number is 4D3773 if that helps.
I got it from a farm owner who bought it from someone else. I have no idea what base it originally came from.
Thanks in advance. I will definitely send you a donation after.
The hyperlinks in some posts are from using a browser on a mobile device. It thinks they are a telephone number. I just went back and retyped mine.
Vehicle Use Code: | ||||||
Nomenclature: TRUCK CARGO 2-1/2T | Model: M35A2 | NSN: 2320000771616 | ||||
Serial Number: 52515917 | Registration Number: 4L55470 | Year of Mfg: 1970 |
Thank you for providing your time. The truck is a 1970 M35A2
Serial number---------052511431
Registration number--04G12570
NSN number----------2320000771616
It was bought from Vandenburg AFB
Bumber# left side--40x right side--CM31
Serial Number: 52511431 | Registration Number: 4G12570 | Year of Mfg: 1970 | ||||
Manufacturer: 65909 |
sounds great, thankscarnac, i made my donation to the foundation with the proper ss notation a couple of weeks ago. Thank you for all that you help us with.
It appears you have the serial number wrong. I have no record of a 340 for any trucks that are of that stock number. It should be either a 0540 or a 0640. You will need to check the serial number on the frame. Read post #1 for the location.Hopefully you can get this one figured out. GL sent me paper work for a 1989. Louisiana motorvehicles (while I was watching) finally used my serial number for my license on the front bumper. However, entering it three times into their database system came back to them as NOT a 1989 model. But their system would not say what the actual year was. But it is now registered as an 1989. Here goes everything I found on the original sale. This deuce was purchased out of Huntsville, Al.
Serial number is 034011912
Truck Cargo. DTID HQ057013365201 Manf US> Army Tank Automotive Command AMSTA-1M-MM U.S. Part#8736733 FSC 2320 NSN2320009260873
Painted on the underside of the hood in three inche stencil is the following, Anti-F-O-76-77
It would be good to know if this is a 70's model Deuce as there are a few insurance companies that will insure it cheaper at the collectors rate. Thanks for your time and effort. Donation shall be forthcoming.
1968 Kaiser M35A2 W/W
Serial number---------053910301
Registration number: none
NSN number----------2320000771617
It was bought from private seller in Elko NV
Bumber# painted over
Thanks for the help
Aaron
Nomenclature: TRUCK CARGO 2-1/2T | Model: M35A2 W/W | NSN: 2320000771617 | ||||
Serial Number: 53910301 | Registration Number: 4C37271 | Year of Mfg: 1971 | ||||
M35A3C w/o winch
Contract No. DAAE0793CR110
a. 501173
b. NK0GM6
c. 2320013832050
d. Ft. Knox, KY
e. CONG 1157 FSC F231
Thanks
Nomenclature: TRUCK CARGO 2-1/2T | Model: M35A3C | NSN: 2320013832050 | ||||
Serial Number: 501173 | Registration Number: NK0GM6 | Year of Mfg: 1994 |
Nope, it isn't right. As per post #1 there ain't no I and there ain't no O s in the military. It's either a 1 (one) or a 0 (zero) but I'm in a nice mood today so I won't pull an R. Lee Ermy on you (LOL). I don't want any of you other numbnuts getting any idea that I'm in a nice mood today. I just had a moment of weakness.M923A2 WO/W
A. 1001AB029
B. NLOQ5R
C. NSN 2310010502084
D. Germany
E: 167 2 (not printed clear)
I hope I got it right. Thank you again.
Nomenclature: TRUCK CARGO D/S 5-TON | Model: M923A2 | NSN: 2320012300307 | ||||
Serial Number: 1001AB029 | Registration Number: NL0Q5R | Year of Mfg: 1989 | ||||
Manufacturer: 47457 | Contract Number: DAAE07-86-C-J111 |
