rodman68
- 0
- 0
- olympia, Wa
I replaced all eight glow plugs from the wellmans to ac 60g four of the wellmans were open. Definately helped it starting but when it didnt start very good the other day. Checked all 60g all ok during glow plug cycle had 9.0 volts on the output of the relay. Next day I checked the input to the relay 9.0 volts also so the relay seems ok. Next day checked the bus bar terminal that goes to the resistor and had 23.6 volts. So I am dropping 14.6vdc across the resistor that seems excessive, what I understand is I should have 10-13vdc at the glow plugs. Tomorrow I will check on the glow plug also to see what voltage I have there. So is this voltage drop a little on the high side?
