scottladdy
- 8
- 18
- CT
Lot's of Charging System Questions ...
Some simple answers, but please spend some time searching the forum. I think you will gain a much better understanding if you do.
Search for Gen2 relay (and search variants like Generator 2, alternator 2, etc) for your relay questions.
Search for Gen2 diode.
There is no relay for Gen1.
I know you are anxious to resolve your issues AND understand all of the details of the charging system. Please trust me in this. Take it systematically one step at a time. Before you know it, (but probably not soon enough ) you will start to understand the details. Just take your time and continue to study the TM's and the forum.
WOW, lot's of questions.I have been studying the TM for the charging circuits and I have a couple of questions:
1. At the bottom/middle there is a diode. Because it shows wiring passing through the firewall harness plug it would seem that this is an external component to the alts. Is that true or is this a representation of the internal diode? Just by the logic of the circuit it would seem that the "exciter" circuit for the alts. is controlled by this diode and thus would be critical to its function.
a. If external, could it cause gen 1 to not charge?
b. If it can disrupt charging, where is the little guy physically on the truck and where do I get a replacement?
2. There is a relay "GENERATOR #2 RELAY" noted on the schematic on the right side just above the mid point.
a. The schematic shows no control circuitry for this. I would presume it is controlled by the ignition. Correct/incorrect?
i. Or, is the plug looking icon below it the wiring?
ii. If so, where do I find "Figure F-4" for the continuation of the circuit?
b. Could this relay affect the ability of the circuit to charge the battery(ies)?
c. If so, where is this relay physically and, where do I get a new one if its bad?
d. If there is a relay for GEN 1, is there a relay for GEN 2 that is noted somewhere else?
i. If there is no GEN 2 relay, why? What does it do for GEN 2 that GEN 1 does not need?
Thanks for your help!
