Draft Pads
GUNNY 155
elgin illinois
I know I am going to take a beating on this one but in the spirt of sharing helpful information with my fellow HMV restoration brothers here goes. How many sets of draft pads have you ruined trying to get them over the clutch and brake pedals. Or have you just given up and let the wind, dust and oil fumes blow into your cab. I ruined 6 trying to get them on. I tried heating them in hot water, cutting them and gluing them with trim adheasive, soaking them in various fluids to sofen them, all failed. Now here is where the beating starts, dont ask why or how I thought of it I guess I was out of other ideas. Coat the pad and pedal with KY lubricant and they slide right on, rinse with warm water and your done. Okay, open fire.
:tank:
vtdeucedriver
Vermont
Got mine on with the first try!! I have a method. I really got to get it on film for John Bizal to put on his site, just have not had time
o1951
155
Bergen County, NJ
For 25 years or so, I have been doing it a bit different - works a treat.:popcorn:
Coat the pad and pedal with KY lubricant and it slides right in, rinse with warm water when you're done.
T. Highway
53
S.E. WI & S.E. TN, USA - Earth
Storm,
You made me laugh so hard I thought I was going to have a stroke.
Gunny,
I got my draft pads on in the first try. Chemicals are your friend to soften them enough and install them.
Bert
Storm 51
Just a Grunt
9
Seattle, WA
I'm glad you got a laugh, Bert! I sissied out and changed it before I got in trouble. :-D
It was too tempting of a straight line to pass up.
That's why I'm always in trouble..... :(
Storm 51
M-37Bruce
59
Midlothian, VA
I've ripped three separate pads & gave up! Now I gotta find/buy some KY & do it tomorrow after work, this is exciting....... :mrgreen:
BTW, Thanks Gunny!
o1951
155
Bergen County, NJ
Storm, I got your original message before you modified it. I doubt you would have gotten into trouble. The state of Kentucky is a great state with a Lot to offer. Stay away from cities, lotsa land to park & run MV's, no ordinances forbiding parking.
Storm 51
M-37Bruce
59
Midlothian, VA
Well last night after dinner I asked my wife & son if we had any ky jelly? I thought my son was going to fall off the chair, my wife looked like she was going to burst! After tings calmed down a little, I explained myself, I'm getting old, so I figure I can get away w/it! :confused:
Well after work today, I stopped off at the cvs, instead of going for the Kentucky jelly, I bought the store brand, less than 1/2 the cost, glad I did, it worked like a charm!!
BTW, My son thinks I cheap just because bought the store brand, I'm just thrifty!
AN/GRC-46
SW PA 15102
I didn't have any KY jelly so I tried some grape jelly we had in the cupboard. It just made a big mess. Seriously, soaking the pads in hot water for several minutes followed by silicone spray lube on the pedal and pad made easy work of the installation. I just couldn't get the pads to stay in place on the floor.
Storm 51
Just a Grunt
9
Seattle, WA
O.K., I'm sorry to resurrect this thread again, but, even using the KY Jelly, I could not get those draft pads on.
Do I need to heat them first, or is there something else I need to do to get them to stretch over the pedals (my wife and son get a good laugh out of me going out to the garage to "play with KY and my truck"; my daughter just gets really embarrassed). :p
I'm not having much luck with this process, but I am providing a dependable source of household humor. :oops:
So, any additional help or hints would be greatly appreciated.
Thanks!
Storm 51
M-37Bruce
59
Midlothian, VA
I used a wooden wedge that didn't have a sharp edge (similar to a door stop) it persuaded the lip of the draft pad..... it just slid over the head of the..... pedal! fat lady sings
Storm 51
Just a Grunt
9
Seattle, WA
Thanks, Bruce!
Did you heat it up at all? I imagine I can find half of an old wooden clothes pin to use as a wedge.
Off to find a suitable wedge...........
Storm 51
Storm 51
Just a Grunt
9
Seattle, WA
Well, I got mine on, but they are torn a bit (not completely, but about half way). They will work for now, and when I'm feeling ambitious, or need something to add to an order from MWM, I'll get another set and try again. I think that if I would have heated them a bit first to make them a little more plastic, that they would have gone on fine. I now have a better idea of what I'm doing, so hopefully my efforts next time will be a little more successful.
Thanks for all the help and suggestions!
Storm 51
M-37Bruce
59
Midlothian, VA
I have a few extra already, you should do the same, they aren't going to get any cheaper. Stored properley they should last a long time.
vtdeucedriver
Vermont
I do have a trick that works for me and thought it was not KY, but similar. I have a prior trick that is just as important. Now I ran out of time last yr but John Bizal sent me some NOS and Repro Draft pads as a test. I told him that I would do a "How To" video for his web site as this pretty much has been the #1 problem with owning a M-37. I did mine with NOS ones years ago and they are still on there fine. The reproduction ones are a tad stiffer but should still be ok for my install.
In a couple of weeks, I am setting up a M1950 Hex tent as a back drop for my "in the field" video. I am sure that I will not win any awards at the box office but if it helps take away the frustration from a few fellow M-37 owners, that is enough.
