almalo1ny
- 0
- 0
- Langley/British Columbia
Hi everyone. So I have a A3 and it's been great other than a few expected issues that I fixed. (Altornator upgrade, added a 12 V fuse panel, bulbs) anyway, Here is the issue and I'm baffled. PLEASE help. I'll start from the beginning.
1. Had a leak in one of the air tanks. Bung was leaking.
2. Removed tank to weld but too rusty. Parked truck.
3. Found new tank. (NOS)
4. installed new tank.
5 CTIS would start to work but could not charge air. It was bouncing around at 3-7 psi. then after a while flashed "FLAT"
6. looked at air lines and found two leaky connectors which probably started leaking from me messing around removing tank.
7. Replaced fittings.
8. Same issue....
9. Cant find a leak anywhere else and tires actually have around 27PSI. No Flats.
On a side note I did have the truck running for a while (25 min.) when the tank was out and I had forgotten to turn off CTIS. Did I ruin it? I looked for codes but no blinking on buttons.
8. Same issue....
