dyocis
- 0
- 0
- Paso Robles, CA
I've read through several threads about people installing aftermarket headlight wiring harnesses and the varying quality and prices.
My question is, if I install a set of relays into the stock wiring harness that draws +12v from the engine wiring harness block and uses the stock wiring to the headlights, will it fry the wiring harness? If I do this I will replace the headlight plugs with ceramic connectors to prevent melting.
Also, I will be adding a third relay for the high beam to activate the low beams when high beams are activated.
Is this a bad idea? Do I need to replace the stock wiring with a bigger gauge?
Attached is what I'm planning on doing.
