alburms311
- 0
- 0
- Hayden, AL
So I completed the oil pan gasket/broken bolt extraction project this weekend thinking I had resolved my oil leak issue. It still leaks. I was certain the leak was coming from the front lip of the oil pan between the two bolts there, but apparently its just running down from behind the pan and then between the two front bolts, making it appear to be coming from the pan. It’s is a very slow leak and it isn’t constant. It leaked for maybe 3-4 minutes or so after I re-filled the oil then stopped. I drove around for 30 minutes then parked it, checked to see if it was leaking and it was, so I went in for the night. This morning the same amount of oil was on the ground as has always been. I'm getting around a 4-5 inch diameter spot on the tub I have under the vehicle, just to give you an idea of how much(or little) its leaking. What else in this area could be leaking, and why is it not a constant leak? I have looked from the top down and the bottom up, but no dice. Its not a big deal considering the age of the vehicle, but I still would like to fix it. Any help would be appreciated!
