MilSpec78
- 3
- 0
- Saratoga Springs, Utah
So I have not been happy with the tire pressure on my deuce. The rears appear to have too much pressure and the fronts too little. By sight, I set the fronts to 32 psi and the rears to 24 psi. It still didn't seem right but it drove fine.
I have Continental 18 Ply 14.00-20 tires with NATO tread. I found their specs online and I noticed the Static Load Radius (SLR) is 23". If I understand SLR correctly, that is the distance from the center of the hub to the ground when the tire has the correct psi pressure for its particular load.
My particular tire also has a 9,960 lb max load and a max psi rating of 95. That is about a 104 lb to 1 psi ratio. Considering the estimated weight of the front end of the duece, I guessed the psi for the front would need to be 30 to 40 psi and the rears which have much less weight (the truck is bobbed and has no bed currently) should be between 15 and 20 psi. These were just guesses not knowing the true load of each tire.
Today I measured and measured and measured the wheels. I also adjusted air pressure. The driver's front was at the correct SLR at 38 psi and the passenger's front was there at 44 psi. However, I made it down to 10 psi in the rears and the center hub was at about 23.5". I did not want to go below 10 psi.
I took the truck for a drive and it felt fine. A little more sluggish though. Is 10 psi too low for the rear? Does anyone else run their rears this low?
I saw a spec that these tires can be run as low as 8 psi. They also look like they are sitting properly. See the attached pics. At 24 psi the edges are rounded up but at 10 psi the bottom appears to sit correct.
Thoughts?
Thoughts?
