Stan Leschert
- 87
- 0
- North Vancouver, BC, Canada
In Florida, I would just use a black drum for heat.
You can get a cheap 12 V pump to run it through your strainers a couple of times,
and then push it through some progressively smaller Racors.
I wouldn't use an immersion heater, you want to heat to medium, not boil it!
On your solar heating drum, tap in a spigot about 4 in from the bottom.
That should allow you to drain product, not waste.
Run it through a couple times if you have to.
Do a search, many others have done this before.
You can learn from their mistakes, and not have to repeat them ....
Unless you are really stubborn!
