- 9,582
- 226
- 63
- Dickson,TN
I've searched the TMs for two days and I'm sure I'm overlooking it but for the life of me I can't figure out how to troubleshoot my fuel solenoid.
When I first got the MEP 003, I test ran it using a slave cable (it had no batteries) and it fired right up and ran fine. I then parked it in the shop and it sat for a couple of weeks. I finally got some batteries and tried to fire it up again but it would just crank with no smoke. Upon further inspection I discovered that my fuel solenoid wasn't working. I was going to just run a 24v jumper wire to the solenoid to see if the solenoid was bad or it wasn't getting power but I'm unsure which wire is 24v and which wire is ground.
Correct me if I'm wrong but the way I understand the wiring diagram, 24v goes through the temp switch and the oil pressure switch before it gets to the solenoid. I guess what I'm wondering is where the solenoid picks up it's 24v?
