motormayhem
- 6
- 18
- Tucson, AZ
My truck sat for about 4 months without being driven while I was away. When I went to start it up again I thought it would be a good idea to lube up the top end of the motor before starting it so I disconnected the cutoff wire from the IP and cranked it over for about 10 seconds without it starting. Then I hooked up the primary again and it fired right up. I let it sit and idle while I finished putting stuff away and closing hood,etc. Anyway it idled great for about 2-3min and then all of a sudden it started bucking and shuttering (like it was running on 7 cylinders which I think it was). I opened the hood and took the air filter off and it was making a weird ticking/slurping noise out of the intake and more smoke than usual out the exhaust. I shut it down right away and went inside thinking it broke a rocker or something, but when I went out again it fired right up and ran like a top. I then drove it for the next 4 days and it ran normal except for doing it once as soon as it started after being parked for about 2 hours. This time I just drove it and it was gone before I got out of the parking lot. The truck then sat again for another month before I drove it again. It again ran normally except for 2 times over the course of a month where it did it right after starting and only till I drove about 300 ft. I haven't done anything yet to try and figure it out, but wanted to see what other people thought it was. I was thinking maybe a sticky valve? I threw a bottle of marvel mystery oil into the crankcase to clean everything out but it was only in there for a day before I had to leave again so I wont get to drive it a little and then change the oil and see what happens for a few months.
