- 34,012
- 1,806
- GA Mountains
The following attachment is from TM 9-2320-209-34-2-1. This is the commonly available TM in PDF format that has rebuilding instructions for the air pack. The attachment is a page right from that TM. The "Note" at the top explains the difference between the piston cup and pushrod seal. The TM says the piston cup has the larger hole (see item 2). This is wrong. The pushrod seal has the larger hole and the piston cup has the smaller hole. This should help those rebuilding airpacks.
