sewerzuk
- 12
- 18
- Seaside, OR
The TM says it is "critical."
For those that have tried to load test and/or operate their sets with a known timing problem, how did your set run? Was your timing too early or too late, and by how much?
I have swapped quite a few IP's on -002's and -003's, but I've always taken the time to swap in the correct button to get the timing withing 1/2 of a degree mark. I have an -002 in my shop right now that is running 1.5 marks (3 button sizes) too late. I was just going to wait for the correct button, but I thought I might load test it tomorrow just to see how it actually runs. Under no load, it seems to run exactly like a correctly timed -002a...
Is 1 button size OK? Two? Where is the line where the set simply doesn't run well enough to be considered running properly?
