Vhyle
- 1
- 0
- Clarksville, TN
So now I got the new fuel pump pushrod and new pump installed. After cranking a lot, and sucking air out of the system with a Mity Vac, it finally runs!
But now, I have 3 or 4 leaks at various fuel injectors. I did crack them open before to aid bleeding. After tightening them all up, I still have these leaks.
So now, my next move is to loosen them all up and check the fittings for cleanliness and proper sealing. Some of them look like the leaks are coming from under the fittings, some of them coming from the rubber drainback tubes (which a few of them look pretty shotty), and some of them look like it may be coming from the injector itself, closer to the heads.
Has anyone else had this issue? I didn't take the lines off at all; I simply loosened them a bit. I looked at the TM to see if there were any sort of washers that may have been messed up during the process, but the only washers I see go between the injectors and the heads. I want to try all possible, simple diagnostics before I rule out the injectors themselves being bad. I don't think that's the issue anyway, since they didn't leak before.
