OK, now I have a delema.
Would you like me to apoligise in a PM, or on this thread?
Would you like me to delete all the crap and leave just the correct info?
Your call.
I clearly misunderstood both your question and the fact they have reverse lights(I did look quickly in the TM).
Your reply about not having time to read the TM, sent me in the wrong direction and off topic.
I'm sorry I replied as I did.
Was your(does it need to be) 3 lever switch in service drive, when you tested for the reverse lights?
Here is the link to the A3 wiring schematic hope it helps.
http://www.xm381.com/xm381/TMs_files/A3%20Wiring%20Diagram.pdf
For what it is worth, I did the best I could to get them to work, had no luck till I replaced the light fixtures. Both were bad and would not work.
Put two new ones on, added bulbs and away it went!
